RCU Forums - View Single Post - Help Installing Saito 1.20 in GP Spacewalker
Old 07-16-2003 | 04:09 PM
waagbuck's Avatar
waagbuck
Default rotating carb
The OS 1.20 can rotate the carb/needle 180 with just two screws. I would assume the Saito would as well, but I'm not sure. You would install it so the needle valve and throttle arm are in the most convenient/accessible locations. Good luck.
