RE: adjusting needle valves - which direction -
I have never heard of an NV (low or High) that turned clockwise to open. More than likely your low end was rich, which was causing the engine to quit at idle. When you turned it CW, you leaned it to it's proper position.
Normally, either side is clockwise to close, CCW to open
