RE: adjusting needle valves - which direction -
wow.. Thanks for such the quick responses.. very much appreciated.
I can say for certain that from 1/4 throttle to full throttle, it ran fine. no problems getting to those high RPM's quickly and with not much sputtering..
high end was not an issue..
and i was really getting pissed because on this GMS was just getting worse as I turned the low speed idle CCW.. Shortly after I started turning it CW it started to run much better.. it idled well and then went to wide open very nicely..
I justdidn'tknow for sure which way the high speed turned to make it richer/leaner..
I still think as I did originally that the high speed CCW is richer and CW is leaner..
Why the low speed is opposite, I don't know..
maybe because it is a "cheaper" motor, the post above may apply..
Thanks.
Pete
Either way , thanks much for the commenting!!
Pete
