RE: Problemson my GP Escapade ARF/ Glow
If you used only one servo for the wing it's going to be very tight under the canopy to install all the electronics. Using a servo on each aileron takes that servo out of the fuse and opens up the under side of the fuse so you can put your battery there. You will love this air plane. Which engine are you running? I have an OS55Ax in mine and it really hauls the mail.
