 Problemson my GP Escapade ARF/ Glow >
Old 03-30-2010 | 07:00 PM
My Feedback: (7)
Default Problemson my GP Escapade ARF/ Glow
Where do i mount the receiver and battery, theres not much room in there. It worked out great until i put the wing on and it wold'nt fit. Anybody have one of these much help is appreciated.
Old 03-30-2010 | 08:58 PM
MetallicaJunkie's Avatar
Default RE: Problemson my GP Escapade ARF/ Glow
http://www.rcuniverse.com/forum/gall...readID=8067138 look through those
Old 03-30-2010 | 08:59 PM
My Feedback: (10)
If you used only one servo for the wing it's going to be very tight under the canopy to install all the electronics. Using a servo on each aileron takes that servo out of the fuse and opens up the under side of the fuse so you can put your battery there. You will love this air plane. Which engine are you running? I have an OS55Ax in mine and it really hauls the mail.
Old 03-30-2010 | 09:05 PM
oldvet70's Avatar
My Feedback: (10)
If you used a single servo in the wing put the RX in the called for location, on top of the servo tray, but put the battery next to the fuel tank, unless you are using a monster battery it will fit, my wife has an 1100MaH battery in hers.
Old 04-03-2010 | 10:24 PM
I've got a 4 Cell Rx pack and the Spektrum receiver on the front of the servo tray on mine. With a Saito 72 it balances perfectly.
Old 04-11-2010 | 10:20 PM
I also ran into problems because I used only one servo for the ailerons. My wing wouldn't fit, so I placed the battery on top and the the remote receivers on the bottom. This is opposite of what the manual says, but I maidened the plane today at it worked okay.
Hey Oldvet70-
How did you fit a 1100 mah battery next to the fuel tank? I thought about it, but I didn't think the battery would fit.
Bjfrankl
Old 04-12-2010 | 07:48 AM
I placed my 1100 NiCad flat pack on top of the fuel tank, the fit was perfect. Also since my Escapade came out slightly tail heavy, by putting the battery where I did, I did I did not have to add any weight. I have a Magnum 46 XLS in the plane and it has been flying great for over a year.
Bruce
Old 04-12-2010 | 08:31 PM
I never thought of placing the battery above the fuel tank...I guess I didn't think it was an option. I assume you have the batter wrapped in foam?
Bjfrankl
Old 04-12-2010 | 08:57 PM
oldvet70's Avatar
My Feedback: (10)
Hey Oldvet70-
Bjfrankl
[/quote]
I just moved the fuel tank off center and the pack fit right next to it.It is a tight fit but thats okay.
Old 04-13-2010 | 07:01 AM
Both battery and tank are wraped in 1/4 inch foam. Works very well.
Bruce
Old 04-16-2010 | 08:25 PM
I use a battery pack with 4 AA batteries. Also have one servo for airelons. I put the reciver infront of the rudder and elevator servos and battery in front of that. Kinda tight but fits. Had to use a fastener to keep canopy closed(magnets not strong enough)
