Hi,
Yes, there is only 1 small adjustment you will need to make to your ECu setting... that is to lower down your glow plug power from 40 to 30...
check out
http://www.rcuniverse.com/forum/m_92..._1/key_/tm.htm
Enjoy =)
Isaac
ORIGINAL: Jetpilot24
I just recieved my KingTech K-80. I did get it mounted on the test stand and had the opertunity to run it up. All I can say is WOW. She fired right up with NO adjustments needed to the ECU. I did 2 run ups on her, and she ran perfect both times. I plan on doing a few more test runs this Friday 4-2-2010 at the Nighthawks in North Jackson, Oh. Anyone wanting to see this new motor is welcome to come out.
Once My F-86 is done, it will be the home for the K-80. I will post pics of the install in the F-86. The F-86 is going to make a good platform for the K-80 as it is 17.5 pounds of thrust.
Here a few pics of it on the test stand.
Joe Lewis
KingTech Rep.
