RE: SR speed controller on CP
Solman,
They are both 10t pinions. The brushed motor pinion has a larger diamiter with wider gears. The brushless motor also comes with a 12t that is about the same diamiter as the brushed 10t. There shouldn't be any ill affects but is needed for proper meshing.
