RCU Forums - View Single Post - Skygate Hawk & Tomahawk Hawk ducting
Old 03-31-2010 | 02:58 PM
marc s's Avatar
marc s
Default RE: Skygate Hawk & Tomahawk Hawk ducting
For those interested here are a few shots of most of the items included in the kit:
Moulded glass fibre tank with face strengthening 'ribs'
2 x white resin glassfibre inlet ducts (these require carbon tows to be fitted by the user)
2 x 3.4mm ply turbine formers (replaces original items)
2 x 6mm liteply turbine rails, with extended front sections to increase lateral strength and provide optional equipment mounting areas.
1 x Carbon bypass, size suitable for turbines up to P200 (retains SG supplied thrust tube bell mouth diameter for direct fit)
Former pack for tank mounting comprising 10 x 3.4mm ply components (only 6 in picture as additional 4 x blind nut ply washers will be included in the supplied kits) & 18 x FR4 components (4 x tank mounting straps and 14 x spacers)
Instruction leaflet
That about covers it, I will get some shots over to Ali shortly so he can provide more in depth details.
marcs
ID:	1408533   Click image for larger version
ID:	1408534   Click image for larger version
ID:	1408535   Click image for larger version
ID:	1408536   Click image for larger version
ID:	1408537   Click image for larger version
