RCU Forums - View Single Post - Axiome (Oxai) CG
Old 04-02-2010 | 10:39 AM
amram's Avatar
amram
Default RE: Axiome (Oxai) CG
Well,
It came out with all accessories at place exactly 190mm of the Wings LE.
This with PowerBox Double sensor switch and 2 x LiPO 1320MAH Bat
Located under the Canalize (Can be changed by removing the Canalize)
APC 19X11 prop, and CDI unit just behind the Firewall.
This will allow me to work 190mm of the LE and move it backwards by moving
The CDI unit backwards if needed. The total weight ready for lift-off is 4920.
I hope this will work fine.
Thank to all helpers….
Amram
