RE: Question for Bax about 9C super tx problem
The transmitting mode is usually stored with the model, but you have to cycle the power after you change models...so if you change from a PPM model to a PCM model, you turn off the transmitter and turn it back on. There's nothing wrong with your transmitter because you have to do so.
