gp cap 232 setup?????
Hey All,
Need some help from the more experienced.
I am building the GP Cap 232 .40.
Going to put a Saito .91 in it. After the engine is broke in good what prop would be best .
I did build the wing for 2 aileron servos.
Everyone says this plane comes out tail heavy so I was thinking of putting the rudder servo up front with a pull pull system and one servo for the elevators.
? Do I center the rudder servo and put the ele servo to the side of it? If so will the 2 pushrods for the ele's still hookup and operate propperly.
I have never delt with pull pull. How should I run them out the fuse near the bottom to the Klett tailwheel's horn on the rudder?
Do I just slit the covering or add some wood and cut holes?
Any pics of some setups would be great.
Let me know what you all think of this plane and what I should expect.
Thank You All and to all great flights.
