Ok i'm sorry i'am quebecer and i have a little problem with my english cause where i,am living nobody speak english...so i try to explain my problem.
Ok.
1. I start my engine and that took two shot on pull-start.
2. i run around to wram it up and be ready to adjust it
3. when his corectly adjusted (i think) i run for about 4-5 minuts and he die or i need to let throtle at half for stay him running.
4. when he are stalled...i need MANY MANY MANY pulling on sthe rope to start it...and he not accelarating good...he took 2 or 3 second ton respond well but if a let him return to idle it will do the samething and if a run with he is ok (without let im return to idle)
5. the exhaust sprayeing fuel..i,am can say that because i can see the fuel passing by the pressurisation fuel line and blowing out by exhaust..but he do that only when is warm...
hope you can understand
