Engine problem need help :)
when i push full throttle, my car dont take is speed like he should do, He are sloww ans after he take is revolution...after 2-3 seconds...and when its make 6-7 minuts i run..i sudently die... what wrong with him ? help i'll be appreciated
and also, what about the smoke in my fuel tank ? my car piss out all the fuel by the exhaust and there is some air bubble in fuel line? do the RTR fuel line on losi xxx-nt is a cheap one ? thx
CA
Ok i'm sorry i'am quebecer and i have a little problem with my english cause where i,am living nobody speak english...so i try to explain my problem.
Ok.
1. I start my engine and that took two shot on pull-start.
2. i run around to wram it up and be ready to adjust it
3. when his corectly adjusted (i think) i run for about 4-5 minuts and he die or i need to let throtle at half for stay him running.
4. when he are stalled...i need MANY MANY MANY pulling on sthe rope to start it...and he not accelarating good...he took 2 or 3 second ton respond well but if a let him return to idle it will do the samething and if a run with he is ok (without let im return to idle)
5. the exhaust sprayeing fuel..i,am can say that because i can see the fuel passing by the pressurisation fuel line and blowing out by exhaust..but he do that only when is warm...
hope you can understand
Ok.
CA
tyr replacing fuel line, presssure line to exaust, then unscrew your highend needle all the way then blow it out with air then replace to factory settings before running it get inline fuel filter
hope this helps.
hope this helps.
CA
yes if u dont have a filter on it dirt and stuff goes in the carb and causes idling problems and also a filter will help extend your motor life .
