RE: RE:
Do you have an Avalanch to check out Wolf?? A standard clutchbell will bolt onto the motor, but you may have to dremel the main shaft, to shorten it, or use something as a large spacer to take up the extra length of the output shaft.. Only other thing that prevents you from using a standard bell, is moving the motor forward so the bell/pinion-gear lines up with the spur gear.. Have to see the motor mount on an Avalanch to know if it'll accomodate the motor moving forward or not.. Might need to make some new holes in the chassis for the motor mounts as well.. It's pretty straight forward stuff, just need the clutchbell to line up with the spur.. Good luck bud!!
