RE: AMT 180 PROBLEMS
So do you no how to put the AMT 180 back togeather? I just did mine you have to have that turbine wheel balanced wright I had it done then I put the rest back togeather. you have to go threw the front of the defuser with the two washers then the tampered washer then the lubrication ring then the bearing and the small washer in back of the compresser wheel.
