RCU Forums - View Single Post - How to start a glow engine?
Old 04-08-2010 | 03:14 PM
ArcticCatRider's Avatar
ArcticCatRider
Default RE: How to start a glow engine?
Loosen the plug a 1/2 turn or so to relieve compression. Then put your glow igniter on, and pull it. It will be much easier, and if fuel is in the chamber, it will fire. Once it's running, remove your glow igniter and tighten it up.
It may die after you remove the igniter because of how rich it is for break it. In this case, use the glow igniter to tighten the plug as best you can.
If your unsure if there's fuel in the motor, take the glow plug out and rip the cord. You should see a mist or droplets fly up. If it's flooded..you'll see lots of them.
Is the needle open to the recommended setting?
