RE: Stabilizer halves of different incidence? What gives?
Hi Jason!
I'm using a laser meter. First I used the canopy as a reference point set to zero. Then I took readings around the plane 5 times to be sure I got everything right. I don't know how to check my motor thrust lines with what I have, but from the best I can tell using a level and my eyeballs it looks like I have the normal right thrust and down thrust built in. And, yes I found Bryan's article on trimming during my search for insight on incidence. Really a wealth of information in his [link=http://hebertcompetitiondesigns.com/triangulation.aspx#]Triangulation Article[/link]. Thanks for the tip though. Definitely a "must read"!
Joe
