RCU Forums - View Single Post - Help Needed - mCX
Old 04-11-2010 | 08:25 AM
matty_p80
Default RE: Help Needed - mCX
hey AK!
although 99.9% of the time the E-Flite products are right on the money, they are experiencing problems with the micro plugs that connect the motors to the board!
i have the mSR and have had the same issues! the remedy for which (you're not going to be too plussed with this one!) is to unsolder the female side of the plugs from the circuit board then solder the plug pins directly onto the CB, making sure you mark which one goes to which and correct orientation (i.e. mark the upper side of the motor's plug and do them one at a time!!)!!
hope this helps
Matty )<+}}}}]@>
