realistically anything can be used for drifting so long as it has drift tires. not sure if you could get drift tires for a 1/8 car but you may be able to make them (drift tires are usually just ABS or PVC hard plastic). Ideally you would want alot more but thats all you NEED.<div>what you DONT need is a ton of power</div><div>you will probably want:</div><div>-4WD</div><div>-decent balance front/rear and left/right</div><div>-a locked rear diff</div><div>-a gnarly course to drift on (sounds like youve got that
</div><div>
</div><div>be origional! I like the idea of doing something not many other ppl are doing. you may want to try drccentral.com, there are alot more drifters on that forum who can help alot more than I can.</div><div>
</div><div>good luck!</div><div>Dre</div>
