ORIGINAL: madfreestyler
Thanks for the reply,
Looks like the distance between the holes is 80mm on the fuselage, do you know if that makes it the older or newer one?
Dont suppose you know if the stab with 80mm gap can still be sourced?
Thanks in advance
I dont know the exact chronology of the changes, but all the ExtremeFlight planes I've had are numbered from the factory with matching numbers... my guess is you will have parts of different planes if they dont line up. Three or four digit numbers stamped in blue ink usually. Thor.
