RCU Forums - View Single Post - Sterner - DH 100 VAMPIRE buildingThread
Old 04-13-2010 | 04:34 AM
  #140
petera38's Avatar
petera38
Default RE: Sterner - DH 100 VAMPIRE buildingThread
Further progress...
I have eventually finished the right wing panel. Spent quite some time with the ailerons. Gluing in balsa blocks in wing and aileron, adjusting the Robart hinges plus sanding the ribs to fit the leading edge on the aileron....
The servo tray was done using 2,5mm plywood. On top of that I glued a layer of "Pro-Skin" ( thin fiberglass sheet) protruding 5mm on all 4 sides...
ID:	1417312   Click image for larger version
ID:	1417313   Click image for larger version
ID:	1417314   Click image for larger version
