RCU Forums - View Single Post - Pattern Problems
Old 04-06-2002 | 01:27 PM
Dansy's Avatar
Dansy
My Feedback: (53)
Default Pattern Problems
Question.......on the ground with the aileron stick neutral....after an input does the servo go back to neutral??
I had two radio the had pot that rotate a bit on the gimbal giving roll but in my case it was elevator......electronically I was no longer in neutral, with a 10 X trim 0, sub trim 0, look at screen 75 it will depict the electronic position of the stick.
I found this out because also when I was setting a new plane I could not get full travel out of the servo.
Daniel D.
