RCU Forums - View Single Post - Stinger 60 Modifications
Old 07-17-2003 | 03:59 AM
shenion
Default Stinger 60 Modifications
The elevator setup should be ok. It has the advantage that one of the servos does not need to be reversed. But it may be difficult to get identical throws.
I have the giant one so 2 servos are easier. You might go with a couple of Hitec 225BB servos. They are small enough to fit side-2-side. Or look at a low-profile aileron servo. I was dubious about using the 225's due to their size. But then I saw several pylon racers use them for everything on their "guided missles". I used them with a .91 on my Extra and they outlived the plane.
As the tail is tapered, the servos will not be inline with the horns. I added a 1/8" piece of ply to raise the back end of the servo up. Then the top of the servo is inline with the elevator horn. I also glued a small 1/8" piece of ply inside on the other end of the servo. so both sides have 1/4" ply to screw into.
If there is a lightening hole there, cut a piece of ply to fill the area of the "hole" and ca in place. Cut the servo opening then add a ply doubler behind to add strength to the seam.
All stingers are weak just behind F2. They will break at the front of the wing saddle. There is a small doubler that stops at F2. The plane will split between the doubler and f2. Some have made the doubler extend past F2.
I added 1/2" tri-stock epoxied to f2. Then covered the doubler-F2 joint with fiberglass/epoxy.
I had the .40 and have the Giant Stinger. Both are fun to fly.
