I really need help deciding
What kind of airplane are you looking for?
It all depends on what kind of flying you like.
The Dazzler is more of a FunFly. It flies slow, will fall apart at high speeds. They are a "bang the sticks around" type of airplane good for spins, flat spins, tumbles, and all that fun stuff. It's good for low and slow aerobatics...
The Super Sportster on the other hand is a fast airplane that isn't that great at slow speeds. It's a loop and roll with a spin here and there type of plane...It goes where you point it and does it in a smooth way.
Are you going to get the kit or the ARF? The Dazzler ARF is covered with some cheap "shelf-covering" while the Super Sportster is covered with Ultracote. The "shelf-paper" is hard to repair, hard to keep looking nice, and tends to fade. If you're going with the kits both are pretty good. The Dazzler is a much quicker build that can be throw together in a weekend or two. The Super Sportster will take some more time...
I've had two Dazzlers and loved them both...They get my vote.
