RCU Forums - View Single Post - 2.4 tech question
Old 04-14-2010 | 09:25 AM
BarracudaHockey's Avatar
BarracudaHockey
Default RE: 2.4 tech question
ORIGINAL: Roo Man
Between the brands of 2.4 transmitters of on the market, which uses the most channels for transmitting? I was just told that spectrum uses only 2, can this be correct?
Also, how does the receiver know which channel the transmitter will use next? I assume that the channel sequence is totally random is this correct?
Gary
You really need to put the ideas of freqencies and channels behind you because 2.4 spreads the signal out over its available bandwidth.
