Starting procedure:
Tx on, throttle to low, idle trim to bottom/lowest setting, idle-down 'cut'. (on Futaba the throttle cut function stops the throttle from working, so I use the Idel-down function)
Plug 10S pack to controller, put canopy on and turn radio on (ALWAYS staying away from prop and airplane supported from moving).
Wait for my controller arming beeps to stop, click up to 7 on the throttle trim, flip the idle-down switch and the motor turns 500-600 rpm.
Take-off, fly, land, smile and hope it was worth it
