RE: Setting your E-idle. What's your trick.
Yep usually you have to set a switch with a lower setpoint on the throttle to activate the brake.
I just set the idle as low as possible, I think its around 800rpm with the schulze/pletty. Then a switch to give me a lot of brake power that I only use on long downlines.
