RCU Forums - View Single Post - A really small float plane build thread
Old 04-14-2010 | 10:50 PM
scale only 4 me's Avatar
scale only 4 me
My Feedback: (158)
Default RE: A really small float plane build thread
Worked on the float,
Based on my math, the main float is 22.5" long,, about 3"x3" at the thickest point before shaping. The plans I worked from are RCM Rufe conversion for the Top Flight Zero, those are 41" long, so I had to subtract 45% from every measurement. I first I transferred the profile (side view) measurements and shape onto the block,cut the foam 3x3x22.5 on my table saw,, then, cut the after-body with my bandsaw and rough shaped the nose with my disk sander. I then plunge cut a 1/8" wide slot about 2" deep with the table saw. The main float attach piece, 1/8 light ply, will get glued into that slot. Then I will add foam and shape.
ID:	1418212   Click image for larger version
ID:	1418213   Click image for larger version
ID:	1418214   Click image for larger version
ID:	1418215   Click image for larger version
ID:	1418216   Click image for larger version
ID:	1418217   Click image for larger version
