RE: Engine effects of bad oil?
Ever find a need to pick your nose after a day of clean air flying? More dust in the air than most recognize.
Yes I was a bit generic in my descriptions of what happens with various oils and how they are used. I don't have the time or patience to write a 25 page dissertation on the effects of each and every oil I have tested or worked with. If someone wants to pay me for my time I'll treat it like the job it is and get it done. Yes, there are oils that do little to protect an engine from excessive wear. There are also engines where the quality of plating is so bad no oil can protect them from excessive wear. Some engines have cylinder metals so soft that hard carbon particles leave long smooth ridges under the exhaust ports after only a couple hundred hours. How does one discern the difference? It can be tough, especially for the uneducated.
