RCU Forums - View Single Post - Is it necessary to use washer with prop nut?
Old 04-14-2010 | 11:53 PM
armody's Avatar
armody
My Feedback: (10)
Default Is it necessary to use washer with prop nut?
Hi y'all,
This is me Mody again with a new question and topic. My question is.
With my 2 planes Hangar 9's P51 Mustang PTS and GP's Escapade, I'm using metallic prop nut and using the APC 11X6 Two-Bladed props. I push the prop through the crank-shaft of engine, infact I turn it anti-clockwise to slide through the crank-shaft of engine and then I directly use the metallic prop nut to tighten the prop, I don't use any washer like the prop goes in first then washer and the last one is prop nut to tighten it.
Is it a good practice to use a washer? Using washer makes a difference or not? If I'm not using washer before the prop nut, is my motor in imminent danger?
Please shed your experience light.
Mody
