RCU Forums - View Single Post - Is it necessary to use washer with prop nut?
Old 04-15-2010 | 10:16 AM
DenverJayhawk's Avatar
DenverJayhawk
Default RE: Is it necessary to use washer with prop nut?
Make sure you center the washer on the prop before tightening the nut. The nut on my OS 95 has a tapered end that automatically centers the washer as you tighten the nut. If you are just using something like a spinner nut and you don't center the washer (if still using one), you can get vibrations throughout the entire model.
