RCU Forums - View Single Post - Is it necessary to use washer with prop nut?
Old 04-15-2010 | 12:15 PM
landeck
Default RE: Is it necessary to use washer with prop nut?
ORIGINAL: Gray Beard
ORIGINAL: JohnBuckner
If you are using a spinner nut such as this:
http://www3.towerhobbies.com/cgi-bin...&I=LXE158&P=RF
There is absolutely no need for a washer. I use a lot of these and and infact the machined in nut face is superior to a typical washer, they are intended to be used without a washer.
John
I use these prop nuts like John is showing plus a couple of different types. On some planes these look good and work great. As John stated, no washer needed, they are designed to be used without the washer.
I have been building and flying models for 57 years, the last 37 years RC. In all of that time I never heard of not using a washer with a spinner nut. You learn something new all the time.
Bruce
