RE: Is it necessary to use washer with prop nut?
I don't use washers on mine. There is a lot of contact area between the prop nut (I use Dubro Spinner Nuts) and the prop. I would be afraid that the little bit of contact area between the prop nut and the washer would make the prop nut come loose every time you applied the starter.
