RCU Forums - View Single Post - Is it necessary to use washer with prop nut?
Old 04-16-2010 | 09:30 AM
DenverJayhawk's Avatar
DenverJayhawk
Default RE: Is it necessary to use washer with prop nut?
John,
I am using the stock washer and nut that came with the OS95AX. The washer's hole is slightly larger than the diameter of the prop shaft. So the washer does not center initially when you mount it in front of the prop. But when you thread the nut onto the prop's shaft, it will automatically center the washer as you tighten the nut.
