RCU Forums - View Single Post - battery problem
Old 04-16-2010 | 01:40 PM
ReadyToGo
Default RE: battery problem
I will run through how I plug/unplug etc for you to follow:
1. Plug wall adapter into wall outlet & the other end into balance charging box.
2. Check Voltage of lipo and record before charging - I use one of these voltage Indicators
3. Switch wall adapter on at wall. (red light on balance charger glows)
4. Plug white JST-XH into correct socket. (green light starts flashing)
5. When fully charged flashing green turns to solid green LED
6. Unplug lipo, switch off at wall, and re-check (& record) voltage
hey pgroom,
i was taking a look at your instructions and i have some questions, please:
1) the first thing you do is to connect the wall adapter (that is already connected to the charger) to the wall?
2) then you connect the adapter to the charger?
3) only after that you connect the charger to the battery?
4) what do you mean with the instruction number 3? the same as instruction 1?
thanks
