RCU Forums - View Single Post - HelpPlease Servo set up Mixing
Old 04-17-2010 | 07:56 AM
tripower222's Avatar
tripower222
Default RE: HelpPlease Servo set up Mixing
ORIGINAL: bbrown2828
ok i have my seagull edge 540 and it has two elevator servos so i mixed them on channels 2 and 6 but the problem i have is with the trim when i move my trim it only moves the servo on channel two it will not move the one one channel 6 what do i do here help please
Your going to hate this answer but it cant be done, I purchased a 7c also before I learned it is much more limited in it capabilities than the 9c. Sub trim should work but obviously nothing you would use in flight. You may be able to use a syncronizer in flight.
http://www3.towerhobbies.com/cgi-bin...XCTS1&P=ML
