HelpPlease Servo set up Mixing
My Feedback: (76)
ok i have my seagull edge 540 and it has two elevator servos so i mixed them on channels 2 and 6 but the problem i have is with the trim when i move my trim it only moves the servo on channel two it will not move the one one channel 6 what do i do here help please
I forget the particulars of that radio but if there's an option for LINK make sure it's on.
That or look into setting it up as flapperon mixing, that links the trims. I love Futaba radios but JR's program for dual aileron and dual elevator servos sure is easier.
FL
ORIGINAL: bbrown2828
Your going to hate this answer but it cant be done, I purchased a 7c also before I learned it is much more limited in it capabilities than the 9c. Sub trim should work but obviously nothing you would use in flight. You may be able to use a syncronizer in flight.
http://www3.towerhobbies.com/cgi-bin...XCTS1&P=ML
ORIGINAL: tripower222
http://www3.towerhobbies.com/cgi-bin...&I=LXCTS1&P=ML
Pg 45 of the manual tells how - Ailvator. Be sure to set the aileron portion (still discussed on pg 45) to zero in order to prevent elevator movement when ailerons are moved.
