RCU Forums - View Single Post - HelpPlease Servo set up Mixing
Old 04-17-2010 | 10:08 AM
bruce88123
Default RE: HelpPlease Servo set up Mixing
ORIGINAL: tripower222
ORIGINAL: bbrown2828
ok i have my seagull edge 540 and it has two elevator servos so i mixed them on channels 2 and 6 but the problem i have is with the trim when i move my trim it only moves the servo on channel two it will not move the one one channel 6 what do i do here help please
Your going to hate this answer but it cant be done, I purchased a 7c also before I learned it is much more limited in it capabilities than the 9c. Sub trim should work but obviously nothing you would use in flight. You may be able to use a syncronizer in flight.
http://www3.towerhobbies.com/cgi-bin...&I=LXCTS1&P=ML
Tripower - did you buy the earlier 72 MHz 7C or the new 2.4 GHz 7C. The 2.4 version does allow for dual elevator while the older does not.
Pg 45 of the manual tells how - Ailvator. Be sure to set the aileron portion (still discussed on pg 45) to zero in order to prevent elevator movement when ailerons are moved.
