RE: CA Models ONAS
[/quote]
Hey Mike, what servos are you running in the Onas?
Thank you
[/quote]
Hey Chris being new to Airtronics I did some research and I decided on the following.
Rudder 94773M High Torque (Mark Atwood uses these)
Ailerons Low Profile High Speed 94746M's. I'm using these because I like the specs and thought they would work well. I think car guys are very high on this servo.
Split elevators 94761Z wing servo's. Very small and you have to take the tabs off. I know Chris Fitz runs these on the ailerons and I know of others doing the same but I opted to go with the low profiles. Both the Aileron servos and the elevator servos are as fast as I've ever seen a servo go. All seem to center excellently. I've always considered JR digital servos to be the benchmark for any other brand to meet. Airtronics servo's have always had a very good reputation so we shall see. So far I'm pretty impressed.
I'm running everything off of a 6V regulator.
Good luck, Mike
