RE: lifting tail
tripower222 - per your request. Results of another quick search (but overly simplified):
"Figure 4-20 shows an aircraft in straight-and-level flight. The line CG-CL-T represents the aircraft’s longitudinal axis from the CG to a point T on the horizontal stabilizer.
see attached
Most aircraft are designed so that the wing’s CL is to the rear of the CG. This makes the aircraft “nose heavy” and requires that there be a slight downward force on the horizontal stabilizer in order to balance the aircraft and keep the nose from continually pitching downward. Compensation for this nose heaviness is provided by setting the horizontal stabilizer at a slight negative AOA. The downward force thus produced holds the tail down, counterbalancing the “heavy” nose. "
