RCU Forums - View Single Post - lifting tail
Thread: lifting tail
Old 04-19-2010 | 08:48 PM
  #51
combatpigg's Avatar
combatpigg
Default RE: lifting tail
I'm pretty sure I've seen old free flight designs with a lifting tail mounted upside down. I shouldn't bring that up here because it is confusing to the RC trainer issue. The point is the designer either had a preconceived notion that it would do some good.....
...he actually tested the design with different tails until he found one that gave his design good flight characteristics.
So, I wonder if the designer of the Telemaster tried a flat stab and had elevator trim issues?
Usually that problem can be trimmed out by raising the rear of the wing slightly.
