RCU Forums - View Single Post - Wh300
Thread: Wh300
Old 07-17-2003 | 10:27 PM
rmh's Avatar
rmh
Default Wh300
I flew my new 300 today -
very nice flyer and fully capable of all the IMAC stuff
I only had time for one flight -it was noon and over 100 degrees so one was enough . (sh--!)
I will do a full rundown later on it but the quick version is this:
weight 26.25 lbs - accurate weight.
engine ZDZ80 on tuned can - 26x12 MenzS clipped to 25 "
Balanced exactly on centre of wing spar. (tube)
wing loading is under 30 oz ft ---
power loading is good for all but double upline snaps with solid recovery -a bit soft for my tastes
It is extremely easy to fly .
The only mods I did were to lighten the tail group.
I pulled out less than 8 ounces -and that took some work!
I did that so I could use the light engine without having to add ballast up front.
This plane is really looks larger all assembled than I thought it would .
If you opt for a 100 DA or 3W etc - it should work as is balance wise.
I will probably try a 100 -just to see comparison.
for you 3D wannabees - I tried hovers and a torque roll - and it had easy power management for that -
This week end when the weather is cooler in the mornings - I will see how the rest of the stuff works -
I don't like 105 degree flying weather--
