RCU Forums - View Single Post - batteries question...
Old 04-21-2010 | 08:06 PM
jester_s1
Moderator
Default RE: batteries question...
You shouldn't run soldered packs in airplanes anyway. The vibration can break down the solder joint causing it to fail. A quality pack will have the cells welded so that doesn't happen. It'll also use good cells, which basically means Sanyos. Take a look at www.hangtimehobbies.com for some quality packs. I'm a satisfied customer and can attest that they sell a reliable product.
