RCU Forums - View Single Post - Any AMA pattern contest in central texas in 2010?
Old 04-23-2010 | 06:41 AM
flyintexan's Avatar
flyintexan
Default RE: Any AMA pattern contest in central texas in 2010?
Ace,
Chuck has pasted contest info from the NSRCA calendar. Finding this information the first time is not necessarily intuitive.
If you go to www.nsrca.us there is a pull down tab at the top of the page for Calendar. The first selection on that menu is "Thyme Calendar". Select this one. http://nsrca.us/calendartop/calendar.html Once it opens up, it will automatically show the next few (10) contests for the entire USA. There are three small pull down menus in the right upper corner of this calendar window. The first is "calendar". If you pull that down (open) you can select District 6. This will now list the next 10 contests in District 6 only. You can also pull down the menu that says "List Size" and change it from 10 to 20. Now you will be sure to see all events within our district.
The space city contest is next weekend and should be an excellent event. It would be great to see you there.
If it helps, the current AMA patterns can be found on the nsrca site's "Sequences" page - http://nsrca.us/judging-sequences/schedules.html On the right hand edge of this page you will see links to each AMA class and the FAI class as well.
Hope to see you soon at a contest!
Regards,
Mark Hunt
NSRCA VP, D6
