RE: SD-10g mix question
Hey Jim,
I'm with Arch, what are you trying to solve? You can certainly do that mix. You can use one of the custom mixes and set up the Elev>Rud mix that you want, and then you need to go into the Stick Switch menu (Flight Mode menu) and set up the stick switch. Pick the switch (stick switch 1-5), then which stick you want it to be on (Throttle) and then where on the throttle stick you want it to be activated (Mid stick...) and then last choose whether you want Hi = on, Low = off, or vice versa.
Last but not least, you need to actually assign the mix to that switch, which is in the SW Assign menu (in the System menu). Sorry that's so confusing...it'll seem more straight forward when you do it.
That's an unusual mix though... If you have trouble though, give a shout, and we can play with it at the field.
-Mark
