RE: GST 7.7 Brake question!!!
aaah right, they changed it on the GST ( I have a Genesis... older model of GST)
so, same thing applies, just move those collars away from the servo so that they are tighter against the loops.
If you are just bashing and you want SERIOUS brakes, just remove those two little springs. If you just leave the collars and the plastic bits you will be able to do stoppies. The brakes are that good.
Any more questions just ask here. This used to be a very busy section of the forums... dunno what happened.
