RCU Forums - View Single Post - AFO
Thread: AFO
Old 04-24-2010 | 11:36 AM
tommygun32's Avatar
tommygun32
From: San Diego but living in Dubai, UNITED ARAB EMIRATE
Default RE: AFO
amen....
AFO = Air Filter Oil
ARO = After Run Oil
They are two very different things.
Air filter oil can be a very low viscosity oil that turns very sticky/thready once rubbed together.
After run oil is something you put into the engine (about 3 drops through the glow plug hole) after you've run your engine.
If you are about to break in a new engine, I'd recommend a couple drops of ARO oil in your engine, wrap the head up in aluminium foil and heat it up with a hair dryer (or something better...like a heat gun) and then try to start it. Most new engines will come well lubricated from the factory.
Unless you are ABSOLTELY sure about the oil you have, I would go out and buy some ARO. Having said that...sewing machine oil MAY work ok, but ask yourself, do I want to risk it???
There are things to think about, like can the oil handle the RPM's of a nitro engine, can the oil mix well with the oil in nitro, what are the ingredients or composition of the oils...etc???
I'm not an expert on this, hence, I would go out and buy specific ARO made for nitro engines.
Good luck.
