AFO
Another question regarding after run oil. Is this stuff like the lub oil thats used for bearings in sewing machines etc. I have a bottle of unilube by GRIFFON can i use it; or just go out and but AFO. And something else, I'm gonna be breking in my nitro inthis weekend, should i put a couple of drops in the engine before doing anything or no;also do I use AFO in the carb??
Thank you!!
Thank you!!
AFO is not standard lube oil. It's specifically made to trap dirt; it's sticky. I get mine at the local motorcycle shop. It's foam filter oil that works just as good as anything you'd get at the hobby shop and you can get a quart of it for the same price as a tiny bottle at the hobby shop.
ORIGINAL: K_B
From: San Diego but living in Dubai, UNITED ARAB EMIRATE
amen....
AFO = Air Filter Oil
ARO = After Run Oil
They are two very different things.
Air filter oil can be a very low viscosity oil that turns very sticky/thready once rubbed together.
After run oil is something you put into the engine (about 3 drops through the glow plug hole) after you've run your engine.
If you are about to break in a new engine, I'd recommend a couple drops of ARO oil in your engine, wrap the head up in aluminium foil and heat it up with a hair dryer (or something better...like a heat gun) and then try to start it. Most new engines will come well lubricated from the factory.
Unless you are ABSOLTELY sure about the oil you have, I would go out and buy some ARO. Having said that...sewing machine oil MAY work ok, but ask yourself, do I want to risk it???
There are things to think about, like can the oil handle the RPM's of a nitro engine, can the oil mix well with the oil in nitro, what are the ingredients or composition of the oils...etc???
I'm not an expert on this, hence, I would go out and buy specific ARO made for nitro engines.
Good luck.
ARO = After Run Oil
Good luck.
