Special Perry Carbs.
To answer your question, my experience has been that the Perry is better than most of the stock carbs I've dealt with. On my hoverbatic profiles that is all I run. They have been around a long time starting with Perry, then Varsanne, and now Conley engines distrubuting them. Seems to me that engine manufacturers go through alot of time and pain to make a good engine and then drop the ball when it comes to fuel delivery. I've had excellent results with Perry and OS carbs when I wanted to make a swap. I use the telescoping K&S tubing to make adapters, and also use a Sherline lathe at times to fashion them out of aluminum. Bottom line, if you don't like what you're getting, feel free to experiment. Don't be afraid to go to a smaller venturi either. Those gazillioin rpm ads look good, but at times fall short in the "ease of operation" area. I hate to fiddle at the field. Keep it simple and have fun_bob
