Special Perry Carbs. >
Old 07-18-2003 | 01:47 AM
My Feedback: (28)
Default Special Perry Carbs.
Hi; I would like to know what is so special about Perry Carburetors? I bought a K&B.61 engine the other day that has a Perry carb. on it. It looks like it is made out of black plastic and has a very short NV. I also have a K&B .61 with a K&B carb, its made out of alum. and has a nice long NV. So is the Perry better than a factory carb.? Veco
Old 07-18-2003 | 06:36 AM
K&B's have a history of mismatched carbs.
The 40RC I had came with a .61 carb with a smaller barrel hole. The throttle response was poor and the midrange mixture was always too lean. Apparently some of the .61's came with carbs designed for smaller engines.
K&B has some good carbs and some bad ones and some were mismatched. But they have had enough bad ones that it seems to have become common practice to put a Perry carb on if the engine does not seem right.
Perry carbs are good carbs. They can be adjusted easier than some of the K&Bs. Also, if the Perry Pump is used, a a Perry carb may be required.
Another thing if a carb is damaged on an engine, it is usually significantly cheaper to get a perry carb. On my 25FSR, the OS carb is $57, the perry is $35. You can guess which carb I will replace it with.
Old 07-18-2003 | 09:52 AM
My Feedback: (62)
To answer your question, my experience has been that the Perry is better than most of the stock carbs I've dealt with. On my hoverbatic profiles that is all I run. They have been around a long time starting with Perry, then Varsanne, and now Conley engines distrubuting them. Seems to me that engine manufacturers go through alot of time and pain to make a good engine and then drop the ball when it comes to fuel delivery. I've had excellent results with Perry and OS carbs when I wanted to make a swap. I use the telescoping K&S tubing to make adapters, and also use a Sherline lathe at times to fashion them out of aluminum. Bottom line, if you don't like what you're getting, feel free to experiment. Don't be afraid to go to a smaller venturi either. Those gazillioin rpm ads look good, but at times fall short in the "ease of operation" area. I hate to fiddle at the field. Keep it simple and have fun_bob
Old 07-18-2003 | 10:15 AM
My Feedback: (28)
Default perry carb
Hi; thanks for the feedback, one more question. Can a Perry carb. be adapted to use a remote NV? Jim
Old 07-21-2003 | 05:44 AM
Jim:
Yes.
And you do it exactly the same way you adapt any other - plug the hole where the needle was originally fitted, and put the remote needle in line.
Bill.
Old 07-21-2003 | 08:03 PM
Btw, if you can't find a way to plug the hole where the old needle is, you can just leave it there and just set it to as rich of a setting as you can get with out leaking air. Then use the new remote needle for your actual settings.
A lot of combat guys do this in SSC class to their Magnum engines, using an OS remote arrangement because the OS needles have a much finer adjustment than the stock Magnum needle, but the rules for SSC don't allow direct engine modification, but do allow non-stock fuel arragements like bladders and extra needle valves inline.
Old 10-12-2003 | 03:01 PM
Default RE: Special Perry Carbs.
I guess this thread might be dead looking at the dates but have any of you used a Perry carb on a set up hat wasn't woking with a perry pum and standard carb?
I think I might need to do this on an MVVS 160 that I cant get to run ight with the pump fitted to cope wih a CoG mounted tank.
Cheers.
sj.
Old 10-12-2003 | 03:39 PM
Simon:
I just posted a reply to your Idle Mixture" thread.
Bill.
